grill
yes or no on the grill
  • yes
    Votes: 12 37.5%
  • no
    Votes: 20 62.5%
  • Total voters
    32
At this point, it's not so much a "grille" as a "plug". It's also going to have an effect on the airflow around the truck (incresed wind resistance), thereby affecting your gas mileage. With it in the current form (as in the pic), you're now "pushing" the air with the entire front end of the truck. With a more open grille, some of that air gets through, doing the cooling thing with the radiator, etc.
Not only the engine cooling issue, but if your truck has A/C, it will have to work harder to do its job due to the restricted airflow over the condenser. Your truck has a manual trans, so the cooling of tranny fluid isn't an issue....but the overall underhood temp's gonna rise a bit.
If it were me, and I was dead-set on using DPaluminum for this, I'd lay out some rectangular holes say 1.5" x 3", and cut them out. Space them out....at least 1/2" apart....to retain the DP "look" (some of the raised ridges would still show in places).
Plus, the rectangular design of the holes would keep more in flow with the basic look of the front-end of your truck.
But....that's just my .02 on it.
I think it looks sick but I'd also worry about air flow
i think it looks awesome like it is
I'd suggest using the already existing holes to make slits, lets in me air and still leaves larger spaces of the metal as opposed to continuing to drill evenly spaced holes.
thanks for the idea thats what im going to do :icon_surprised:
just post up plenty of pics when you're done. :icon_thumby:
ok got it done not perfect but not bad for using a jig saw ' drill ' files :icon_welder: and it don't run hot at lest not in 75 degrees:yahoo: if it dose get hotter and overheats i have a fan i will put in it to fix it then :icon_idea:
[/IMG]
what else do you want to see ??? i will post :icon_thumby:
i love it, i might do something like that for a winter cover
Good work there. I'd smoothe the edges out a bit and even it out, but the slightly imporved airflow and a fan should keep the heat problem in check.
I'm still not too sure about airflow but as far as chrome or black, If it's aluminum, I'd chrome it by just polishing it and getting the oxidation off.
I'd say though, it'd look much better with a stocker..Even better if you could find a billet
i just went and put the fan in it today i didnt want to take to chance of it overheating ran it for 10 miles and it stayed a 190 so im happy with that:yahoo: that all that maters
I might Get that Metal in Black, and Line it up with my stock one and mark it out and cut it out so its the stock airflow but with a different look.
ok here is what i wanted to know by black or chrome:icon_thumby:
[/IMG]
[/IMG] let me know what looks better :dunno:
Black all the way. The black trim goes well with the diamondplate. Just polish up the grill. :P
Personally I'd paint the grill black as well, but I seem to emulate Batman in my ride's color coordination lol
