saveatreeeatabeaver
- Nov 8, 2009
The title says it all. Before going in for an inspection, I did a mini inspection just to make sure nothing would turn to shit. Well, I popped off the rear passenger wheel and removed the drum to see what the shoes looked like. The springs/shoes/drum were covered in thick grease/oil. I popped off the other rear wheel to get a feel for how bad this is. The other wheel is fine.
1) I'm assuming a seal broke somewhere in the rear brake/axle. What seal could this have been?
2) I plan on taking this opportunity to change the drums, shoes, and doing the full hardware kit for the rear drums (springs and such). What size are my drums? I could probably pull one and measure, but the thickness tosses in another angle.
3) Anything I should know about the process of drums/hardware/shoes and whatever seal broke?
Thanks
Russ
1996 Ford Ranger 2.3 L 2WD
Thanks
Russ
