LearjetMinako
Gotta love it when you go work on your truck for one thing and find another thing wrong. In long terms. Got 4x new tires and Explorer's wheels. The Auto Tech at Sears said one of my front wheel bearing grease seal was going. Okay, thats no problem. I'll do the work myself and save me the $200 in labor. Got new wheel bearings, grease seals, and synthetic wheel bearing grease. All went pretty much okay. Had Sear's press the new wheel bearing races. And I did the rest. Only problem that I had, I almost snapped off the brake capiler bolt. Hayne's manual said 40ft-lbs, torque gauge never made it that. New bolts, re-try, excpet at 20ft-lbs. All is good and the bearings are done.
Now on to the other, other problem. While doing the wheel bearings. I noticed once again that the engine is starting to leak oil, again. Last time I went in and replaced the front main seal (and the timing belt). Now the oil leak is back and my oil pan is covered pretty good. So this time when I go back in, I'm gonna replace the oil pump seals, replace the water pump, replace the thermostat, replace the timing belt tensioner, and torque all the oil pan bolts. Luckily, I planned this ahead (a year later). So I already have all the seals and water pump. Just gotta go pick up a new timing belt tensioner and thermostat. And hopefully, after all this, I shouldn't need to repair anything else.
When it rains, it pours. But even thou my Ranger is starting to leak oil. It is still the better running vehicle in my family.
