Got my turbo 2.3
Haywire6000
RBV's on Boost
Winthrop Maine
2.3 (4 Cylinder)
Total Drop
2" Shackle Drop
Got my turbo 2.3l a few days ago. :headbang: Came with all the sensors, large vam and LA2 ECU( manual boost controller) for $500. Guy I got it from said the engine was freshened up 2k ago. Going to pull the pan and take a look see to make sure everything looks okay. If so I plan on just installing it and running it. Also going to pickup and ebay inter cooler and a blow off valve( I know what issues it can cause). I plan on doing the swap towards the end of April. I will posts pics then!!! Also, those of you that have done the swap. Any idea what your top speed is? Dumb question I know just wonder ( has to be better than 80MPH).
Also came with wiring harness, already modded to work in a Pinto but I can make it work!
80?? I could hit 110 with my n/a 2.3l with cold air intake 2" flex oipe to 24" glasspack.
I just pulled my n/a and droppex what was supposed to be a running TC motor.....
Blown head gasket, flattened one side ofe every lobe on the cam ansd a bad knock.
Kit should be in thursday, i cant wait tk dig in.
I bet yours is a 4x2 not a 4x4. Quite a bit more weight.
