belovedb2
- Jun 17, 2009
Well the 4.0L is in the beloved. Wiring completed enough to run the engine, sort of. Idles for a short time. One circuit that I have not hooked up yet is the wires for the throttle sensor/O2 sensor. I am a little confused. The 4.0L runs the circuit thru both the clutch pedal position switch and the clutch tripple function switch. (I am assuming that this is to cut the engine to idle if the clutch is pushed or the trans is put in neutral)
On my B2 it does not connect to these switches. I dont even think I have a clutch pedal position switch or the the clutch tripple function switch that would be used for the throttle sensor/02 sensor. Any thought as to how to wire this part of the circuit?
