Got a problem.
92ranger18
Jemison, Alabama
Ive got all my wires ran and everything hooked up and the motor wont turn over anymore. It would turn over earlier but now it wont. Ive put a new batery in it and it would now it wont, ive had the batery charger hooked up to it and still nothin it clicks one time then i have no power. Could it be a loose connection somewhere?
Sounds like a bad connection at the battery terminals to me. But like was was just stated in the above post check the connections at both ends of the battery cables. Check where your ground terminates and make sure that there is no paint there and if its not hooked to the block or heads some where then move it there. Make sure that you have good grounds going from the engine to the frame and body to. This will help with later projects like the stereo or lights.
