laneysbrat
- Aug 14, 2009
In despearte need of help. I recently put a 2.9 liter out of a 1989 ranger into my 1988 ranger. It was pretty much a direct bolt in. The darn thing runs great but I have a oil leak. I have eliminated valve cover gaskets, o-ring at dist. and pretty much everything on top end. Its all new. I am thinking rear seal, but it does not leak at a idle, only when you take it for a drive and then park it, big oil spot. Hate to pull the trany if I can get out of it. Is there any easy way to check the rear seal for leaks, pull starter maybe etc. Any surefire tell tale signs that screams real seal leaking other than a oil puddle. I am a old fart and have a tough time crawling under that thing and looking up into the bellhousing. Any advice would be greatly appreiciated. Thanks Jim from Montana
