- Sep 18, 2010
- Raleigh, NC
- 2.3 (4 Cylinder)
So my '96 Ranger obviously has some nice Bendix dual-piston calipers that do a decent job bringing the mini truck to a stop...
But theoretically what if I went to a setup that had a larger rotor but only a single-piston caliper? Although clamping pressure would be down, there would be more rotor to dissipate heat which obviously helps braking power. There's also leverage, as in the larger the rotor, the easier it is to bringing the wheel to a stop.
OK now for some specifics, the Ranger has a 10 1/4" rotor and is 1.03" thick. The theoretical brake setup has a rotor that is 11 3/4" in diameter and 1.19" thick.
All things being equal (same pads, same truck, ect.) would there be a noticeable difference in braking power, if any? Would the single-piston setup work better than the current stock two-piston setup if the rotors were slotted and if there were high-performance pads?
And for any wise-ass that figures out what brake setup I'm thinking about, please keep it to yourself. Mkay?
