Going back to 235s
Denisefwd93
South East PA
I finally had my truck over to the shop , he put it up and ran it with the wheesl spinning both back tires have flat spots in them. I've been going a bit crazy trying to find the hopping bouncing of the back and the truck doesn't shake. With the wheels off the ground & spinning,
So, I'm going to get the 31x10.5 taken off (should I save them, anybody want them for off road?) and go back to the original 235 75 15 size. Omg ? tires are expensive but what isn't?
I'm not a hardcore off-road and the four-wheel-drive doesn't even work at this point so I can't in any way rationalize any reason for oversized tires.
Good news! looks like I don't need to fix/replace the rear just yet! The tires that were on there were really really bad! (It's just hard to accept because they were nearly new) I'm running on 235s now I won't say smooth as silk it the first time since I've had this truck that I can drive at highway speeds not shake & rattle. This just confirms what I always say, dig hard as you can on for simple things first! The cost of tires is not simple but it's amazing how many problems were caused by bad tires,
Yes I'm still alive , anybody seeing any of this??
Pictures for comparison
The quality of the ride and the absence of shaking, it's like a new truck!
Yes, people are seeing your posts, lol. 47 to be exact...
I have a bad vibration from the front of the truck. I took it to get balanced but made no difference. I suspect the tech was not trained well because I could see a wobble as he spun it on the machine. I'll take it to another place to get a second opinion.
I was beginning to wonder! For a while my post were going to the old forum!
I had wildtrak 31s balanced and rotated maybe four times since I've had this truck. The always remained! It was making me crazy, making me think the rear end was shot or worse
Well, I put about a hundred miles on the truck with the new tires, the shake is definitely gone! the only shake I get now is up around 75 or higher which I almost never do, there still is a lot a body and bed movement because Mount bushings are shot and Lord knows what else. But at least I feel like continuing on with work on this truck now!
He the tire mechanic insisted I keep these tires at 35psi which seems really too much to me, 30-3psi even seems like too much!
Keep an eye on tire wear, if the center wears quicker then lower the pressure.
I always run mine at 36 and get perfectly even wear
I was looking at load ratings, actual load ratings, and gross weight of a vehicle, rangers are +-3,000 lbs can that translates to under a thousand pounds on each wheel even though the front has more weight most likely,.
So looking up a actual load chart the tire pressures on 235s should be 29psi A pickup truck is almost always empty at least mine is.
I guess this changing tires and having good tires on the truck finally is pretty exciting to me because I haven't been able to drive the truck anywhere. it's probably not a big issue to anybody else.
Charts shmarts lol 26lbs on winter tires 36 on summer tires. I never found a chart that means squat about pressure, I go strictly by tread wear. If after a couple thousand miles I can make a measurable difference between the center and side tread Ill adjust. But those numbers have been dead on for the last 4 sets of tires on my truck.
Don't worry I get all giddy when I get new tires too. Mostly because I tend to let them go way too long. :no2:
If you're planning on hauling/towing with the truck, bear in mind that LT-rated tires are going to require more PSI to maintain the same load capacity as an equivalent P-rated tire. So, the number listed on the door placard for the OEM P-rated tires might be ok for an empty truck to maintain a decent ride and not wear the centers, but when you haul you're going to want to bump that pressure up to whatever it says on the manufacturer's tire/load chart to avoid blowouts. I have C-rated BFG All-Terrains on mine and also run them at 36 all around and bump them up to 40 when hauling. I rotate every 5k and haven't noticed any uneven wear.
My truck will always be basically empty, although the cap and the class 2 hitch add some weight to it, I doubt that I'll ever tow anything, the few times I tried I had minor disasters! (With other vehicles)
I'm the same way. My truck hauls kayaks and fishing rods never any real weight. I took a trip to Ohio once with 800 pounds in the bed through hill country and my transmission was not happy. It's a ranger though... it wasn't ment as a heavy hauler. I cringe when I see rangers towing landscaping trailers with tons of gear in the bed. Buy an f250!
The factory tires on mine were 235/75R15s and the pressure for them was 35 psi. Right now, with the 31X10.5R15s, I'm running the same psi. The 40 psi the tire shop put in made the truck ride really rough. I'll keep an eye on the tread wear and adjust as needed but after a few weeks, 35 seems about right. You might need to do the same but the factory psi is usually a good place to start.
Reporting back, I am just tickled that I can drive on the interstate at 70mph even 75 if need be! I have them at 32 psi and even at that there's hardly any bulge in the sidewalls so these trucks are not that heavy I will keep an eye on it, I did have the alignment a couple of months ago it's nice that the steering wheel is centered and surprisingly the ball joints are good.
