- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Okay, for the ones following the one in the suspension? That's not getting a lot of play, and I'll be starting this wing-ding over the weekend.
The parts came off of a 1992 Ford Explorer 2door with A/C.
We didn't check to see if it had auto or manual. (edit: It was the ONLY Explorer we could find)
It took us a good long while to get the coils off....due to RuSt!
My question is:
The rear leaf springs came off pretty easy! However they only have 3 leafs. Most of the photos I've seen (heck, all the photos) show the 3 leaf's and an additional short leaf on the bottom of the spring pack. Kinda like an overload spring? If that makes sense.
So given the rear leaf springs look decent. They only have the 3 leafs. Soooo my question is: Do I just install the new springs and hope for the best? Or should I attempt to break apart my own springs and use a leaf and 'add' my own helper spring. (Keeping in mind my springs are shot and have an actual reverse arc thing going on.)
I'll be hope full the coils make a difference and give me a 2" boost over what I have now. That should with any luck? Kick my camber up a bit so I'm not skidding my tires off. Once it stablizes (and hope it works...) I have a local shop that knows how to align a twin-i-beam front end.
S-
My question is:
S-
