Getting a check engine light help.
mikegpr03
Hi guys..I keep getting a 'left bank too lean code' when i scan the car to clear the check engine light. I have no idea what it is. Any input would be welcomed.
What engine
What engine do you have. If it is the 4 cyl. you shouldn't get that code. But, that code might mean other things too. Check to see if it is one of those multi meaning codes. I get that code on my Lincoln and fixed it with a new O2 sensor
I have a 4 banger that has 8 spark plugs. It has a bunch of meanings when you scan it. But if you were to replace all the things it says your looking at the price of a new ranger.:icon_surprised:
It sounds like you are having the same problem that I am having.
Throwing a code P0171 ?
This usually means air to fuel ratio is too much air. Sucking air from somewhere
its not supposed to.
Vacuum leak?
Dirty MAF?
Help from the experts?
Look for a vaccum leak.
Check for cracked hoses and elbows.
If you spray TB cleaner near a vaccum leak, the idle will change.
