gettin closer to having my interior done
Vonrak
Started my int. makeover with the intention of smoothing dash w/purple bezel/vents. But in the middle of all of it , did a reversal and decided to wrap the interior with Black suede. Here's where I am with it so far.
White face guages,billet a/c knobs
Wraped dash with black suede, metallic silver bezels/vents. Door panels are black suede/purple suede handle/black snakeskin insert with chrome trim and the metallic silver for handle area.
Stuff still todo
Passenger door panel,black carpet,build my center console,wrap lower panel under speedo, and refurbish steering column.
[/IMG]
[/IMG]
[/IMG]
Vonrak
looks great!interior work is tough to do,i tried to do a dash and it didnt turn out as good as yours did.
how did you do the dash? did you have to pull it? was your dash cracked? i ask beacuse my 89 is cracked and i want to clean it up and paint it
I didnt have to pull the dash,thou it would of been a bit easier to wrap if it was. Mine wasnt cracked,just wanted to have something different then stock. Wraping it was not too hard,its making the corners so that they dont wrinkle thats the part that can get ya frustated. Used 3m Super 90 adhesive spray and it worked pretty good.
As far as what to use for a cracked dash,not too certain on it, but there are postings on the 'how to's' for it. a little search should turn it up for ya.
Vonrak
and id say you should add "install shifter boot" onto your 'todo' list.
Vonrak
ill look around, thanks for the tips
