- Jul 15, 2008
- Age
- 38
- Sutersville Pa
- Manual
Can I just get some new bolts from lowe's (galvanized) or do I need something special?
If you buy new bolts get stainless. And when I did my 3.0 I took the torchand heated to hell outta the y-pipe to manifold bolts and pounded a smaller standard socket on then they came out. Then after that when the trans was out. There was room to slip a bolt through the manifold from the front then i put a thin nut on to hold it and basically make a stud but mike are all stainless now and I used nuts instead of bolts to hold the y-pipe on. It comes back off everytime already had to pull motor once and it was no problem
