genral wiring question
iviper123
i have been poking around my new 88 B II, trying to get it working good,
right now the 4x4 dosen't enguage so while i have it on the stands doing the fuel line repair i started looking at the t-case and the shift motor, there is wires going to the rear output of the t-case and they puleed right out...
and the other thing is ther looks to be electrical wire going to the rear diff?????
what would that be..
your shift motor is probably seized, there is a write up on how to take it apart and clean it in the tech library. the wires you pulled out should be OK if you push them back in.
the wires to your rear diff are for your VSS (you know, you can EDIT a post to add more onto it after you post it, should the need arise :icon_cheers:)
