Hello everyone ~
Yet another Ranger owner has been created with my recent purchase of a 2002 Ranger EDGE V6 SuperCab. I bought this truck from it's original owner, a seventy seven year old man. It's got 40K original miles on the 3.0L and is 2WD.
This is actually my first post, I found this forum shortly after buying the truck just last weekend. I have extensive motocross experience and screwed around with sand-rails for a stretch but I have almost zero four wheel off road experience aside from many weekends riding shotgun in my friends Rubicon. I know lines and I know terrain but when when it comes to what works on a truck - what's functional and what's essentially useless - I simply don't have any idea.
Here are my intentions for the truck: A capable and fast pre-runner that will spend it's OHV life mainly on open desert trails in southern California and Baja. I was specifically looking for a 2WD, much to the dismay of my transfer-cased friends, so I'm aware of it's limitations and intend on keeping this realistic.
So far I've done essentially nothing except dropping in a K&N filter, switching to Mobil 1, installing NGK Laser plugs....the basic stuff. Oh and thanks for the Throttle Cable mod....I had about 3/4" slack in that cable.
First order of business: Tires. Any recommendations? Hard pack trails, gravel and clay mainly. This truck is a driver, so nothing too extreme for pavement obviously. Should I keep the stock rims for now? I see no reason not to but maybe I'm missing something....
Next up would be the suspension. I realize the only good way to do this is going to require a couple thousand dollars and more than a weekend - so this is for down the road - but is there any benefit to slapping on a set of Bilstiens or Ranchos to replace the stocks or am I not accomplishing much with that? Any other light mods that will make a big impact before I do a proper suspension rebuild?
I could go on an on here asking a million questions I can find answers to in this forum if I look, but I'm sort of after a condensed primer on a ranger pre-runner, such as what to simply replace, what can be upgraded or modded and where the major performance secrets are. I'm tempted to pull the engine in favor of a 4L, but I'm hearing that a sweetened and cold 3L is a pretty quick motor for my needs; again, I have no idea.This is a 40K engine; all of those Sunday church miles.
So lets hear some thoughts - is this a good base to start with or are we a little weak? I have two "knowledgable" and biased friends with two different takes on this: One says "waste of money - buy a v6 taco or v8 sierra - either way, must be 4X" and another who say's "If you've got around 7-10K, I can build that into a Full Stock Score truck you can handle the 1000 in...." Neither of these theories I believe but we'll see....
Thanks for any info and this resource, which I'm sure I"ll be glued to for a while....
