mbarr69
- Mar 16, 2009
- Automatic
Hey guys! I have a couple of questions concerning off road lights. I want to add 6 off road lights to my truck and I need to know the best way to wire everything and if I would need to upgrade anything to accomplish this.
Equipment;
2 Fog- KC HiLites 57(5X7) series All-Season lights(KC #735). These are 55watts and 7,500 candlepower w/ amber lens.
2 Long Range- KC HiLites 57(5X7) series Long Range lights(KC #740). These are 100watts and 167,000 candlepower.
2 Flood- KC HiLites 57(5X7) series Flood lights(KC #736). These are 55watts and 90,000 candlepower.
My total wattage is 420watts/ that by a 12volt system= 35amps
Here is a diagram I made and I would be using the supplied relays(KC3300 No:2X20A/14VDC) that came with each set of lights. I would like both fog lights to be on one switch, the two long range on one switch and the left and right flood lights on separate switches. I'll be using 10 to 8 AWG wire from the battery to a fuse box holding all the fuses and the same wire going to a box holding all the relays. From there what would you recommend? Please let me know your thoughts and suggestions.
Thank you in advance for any advice.!
Equipment;
