Froghunter
What a day! The end story is that the gears behind the iginition lock cylinder will not keep the truck on. You go to start it and it will start and once the key is returned to the run position it will die. The gears are worn and will not keep the switch on the run position. The truck is an 1988 Ranger XLT extented-cab, 2 wheel drive with 2.9L/manual trans. The question I have is what must be done to repair or replace so the truck will stay running and power on. My Haynes manual doesn't cover this. I know the problem, just need to know how to fit it. If you need picture, I can get them tomorrow.
Thanks!
Froghunter
Thanks!
Froghunter
