Gear Change
john.masce
Grand Juunction CO, El Paso TX
I have a 97 Ranger 2.3 5 Spd the gears are so tall that I hardy ever put it into 5th gear, and on the freeway its a dog. I would love to swap out the gears is it worth it, please help.
John
fastest and cheapest way is to just get a junkyard axle assuming you don't have 4.10 gears right now... you are unlikely to find an axle with lower than that in the yard..
I'm with scott. The fastes way to do it is to find a JY axle with 4.10s. I really doubt that you already have 4.10s, 4.10 gears and "is a dog on the highway" don't usually go together.
they do with 31's and a 2.3... believe me, even with the turbo...
for stock tiny tires, I wouldn't suggest 4.10's, I've had several gear and tire combo's over the years, I had decent luck with the 3.73's and the 235 70 15 tires I ran for a while, but I also didn't mind the 3.08's and 195 75 14's.
my truck originally had 195/75x15 tires/wheels. with the 3.45 gears it sucked... big time, even with a 5 speed tranny! no power and crappy gas mileage. the change to the 4.56's and 31" tires made a world of difference. cruises easily in 5th gear and 21mpg.
i would think that 4.10's would be about right with the 5 speed, providing much better driveability and the option of going to a larger tire later on, if desired. just my $.02.
