gauge questions
derailed
Fremont MI
so I have some mechanical gauges I would like to hook up. but im havin a issue with the temp gauge because there are two sensors at the thermostat housing one is a two wire and the other has one wire. im just not sure what one the computer reads off of for high idle and what not. and for my oil pressure does it matter if I have the oil pressure sensor hooked up or not.
Wouldn't it be fairly easy to UNPLUG one of them and then the other to find which you needed?
But since you did ask... The ONE WIRE is the gauge sendor..
Big JIm
thanks that's what I was leaning to I just wanted to double check myself. I figured someone else has done it before on here
