kohlbeezy
Ok so I finished my 4.0 swap in my ranger and everything is great. Except for my coolant temp and oil pressure gauges do not work properly. I replaced the oil pressure sensor so I know that's not the issue. Has anyone else had this problem? There is a ground strap on the passenger side that I can't figure out where it connects to. it connects to the frame and I'm assuming the other end connects to the block go ground it. Not sure where though.would this be the cause of those gauges not properly working? Thanks guys.
