Gathering information to rebuild my transmission.
I got the Chilton manual in the mail yesterday. I've been looking through it, and it covers removal and installation of things, but nothing of the insides of the transmission. So I'm glad to have the electronic info that Shran sent, as well as the videos to look at.
The transmission jack arrived today! And I've got the lawn mower off the workbench. Time to clean up and prepare to tackle this transmission.
The truck is lifted up! Took me all day to get everything where I felt safe to be underneath.
Each corner has two ways to keep it from squishing me. Plus the 3 ton jack to support whatever I'm needing it for at the moment. I was able to get the drive shaft disconnected from the transfer case last night. Today I hope to get the transfer case removed. I found a video specifically on removing it:
Meanwhile, the battery is having a lovely spa day in the basement. It got a bath, the terminal posts are shined up, and it's sitting in room temperature on a battery maintainer. I've also got the gear shifter and other parts inside the cab removed.
I read last night that the drive shaft is supposed to be marked before removal because it's balanced. I don't know what that means, but I'll mark it today. Hopefully it's in the same orientation as it was when connected, but I didn't pay attention, so I can't really be sure. I wonder how vital this is.
You don't have to mark the driveline where it goes on the axle, that's being too anal... the important thing is the U joints stay in phase, yours likely has a carrier bearing in the middle and I don't think you can get those too mixed up and they're likely keyed at the splines...
Electric T case should be pretty easy, there's that one brown wire that doesn't have a connector if I remember right, the balance weight thing gets in the way so you have to take that off, don't remember having to take the shift motor off...
The hard part is fishing the transmission through the exhaust, it would have been nice if they'd moved the Y pipe 2" forward if I remember right...
Well that's good, because I forgot to mark it again. The front drive shaft came off pretty easy. The top bolt securing the case to the transmission was the most difficult, but I eventually got it. Someone put red thread locker on the bolts. Anyway, the case came away from the transmission easy, and I lowered it with the transmission jack. Only one connector had to be disconnected for the electrical.
I was also able to get the starter motor off too. One of the three bolts was already loose. The other two didn't give me much trouble. I've been under the impression that the exhaust pipe needs to be out of the way to remove the transmission. I got what I think is the catalytic converter out today. The three nuts in the front were fine, but the two in the back were nearly impossible. I tried oil, a breaker bar, an impact driver, heat, a reciprocating saw, and finally a hammer and chisel. I won, but now I can't lift my right arm.
I'm getting a collection of fasteners now.
I can speak to your model but on an early 4.0 it's possible to pull the transmission with the y-pipe in place. Just barely. I cracked an O2 sensor doing it.
Since I already have the catalytic converter out, I went ahead and removed the y pipe too. It wasn't nearly as hard as the cat. I also cleaned up all the tools from under the truck to make room for the two jacks. I have the one positioned under the engine. Got the clutch hydraulic hose disconnected too.
I decided to spend the rest of the day cleaning threads and working on the transfer case.
Today started out nice. Warm sunny weather, and I was excited to finally start removing the actual transmission. Well, I spent two hours removing four bolts, and another 2 hours not removing the fifth bolt. It's not even in the worst location. Second from the bottom, opposite the starter motor. I've tried heat, impact gun, those two things 2 more times, breaker bars, more heat... I'm thinking of grinding the head off and declaring it an alignment dowl.
Before I do something that can't be undone, I figured I'd take a break and complain about it. Maybe you all have suggestions?
Heat then cold? Several times. An inverted can of compressed air is good at getting things really cold. It can get some metals cold enough to shatter from impact.
My main ally has been waiting. I've learned now to soak stuff (literally weeks and months) ahead of time. So I think with heat/cold/and whatever penetrant you're using (deep creep or kroil) and then wait.
I'm going to do my rear suspension in the spring or summer and have been hitting the various fasteners anytime I'm in that neck of the woods.
My mechanic buddy got me on doing the bellhousing bolts from the back with really long extensions, usually needs a U joint on the socket or the sockets with the joint on them, it really helps sometimes then you can get a breaker bar on and really reef on them...
This is the way I've always done them. I have extensions up to 36".
Thanks folks. I had tried the universal joint and extension with the breaker bar. I'll see if I can find another extension and try again. Intact or in pieces, this sucker's coming off.
Bellhousing bolts are just ridiculously tight sometimes. I have had one or two on Ranger pickups that laughed at my Milwaukee high torque impact until I went to one extension with one normal socket (not possible to use that on all of them though.) Generally I can get away with a long 3/8 extension with a swivel socket and a 1/2 to 3/8 reducer on that same gun. Sometimes using a 1/2 extension instead of a 3/8 works better too as it can't twist as much but I prefer the 3/8 most of the time because it fits better in tight spaces and is a lot lighter. Universal joint style swivels don't work well on impacts either.
Less is better with impacts too, one extension is better than 3... swivels, swivel sockets and reducers reduce the amount of usable torque your gun puts out by quite a bit.
Event Coverage
TRS Merch
