PORTnPOLISH
Okay so the first few times I put fuel in I though it was odd that the gas tank was so small because I've never gotten more then 12.9 gallons in it from empty to full. I decided to look it up and I see im supposed to have 18- 20 gallon capacity. The fuel tank looks oem and looks larger then 13 gallons
Also if you put fuel o. To fast its as if the tube is crushed and it clicks the pu.p of so I run the pu
Pump on low.
Pump on low.
