Gas Power Winch
countryboy111789
I was given a Gas powered Winch Simular to the one in the pic. I gottin out of alot of tight places with it. Just wanted to know what ya'll thought about it.
I've seen them. Pretty weak for the price. And I just assume that given that an electric motor has maximum torque at zero rpm and a 2-stroke gas motor has maximum torque at a zillion rpm the electric is better suited for a winch. But I've never used one or heard of anyone that had.
Mine was free.It worked Great yesterday when i was cutting wood. I pulled the Ranger full of split stacked wood and a 4 X 8 trailer with split wood out with it. I doubled it back but it has never failed me yet.
For the one in the pic. Ill check mine when i Go to my shop tomarrow.
Rule RULE Gas-Powered Winch — 3500-Lb. Capacity, Model# G1800E
Engine: 1.83 cu. in. ECHO® power head, Line Pull (lbs.): 1,800 or 3,500, Line Speed (FPM): 32 or 16, Gear Ratio: 115:1, Switching Method: Trigger style, Remote Length (ft.): N/A, Rope Type: Aircraft cable and 6in. x 2in. tie-down strap with 2 hooks, Rope Size L x dia. (ft. x in.): 75 x 3/16, Dimensions L x W x H (in.): 18 1/2 x 10 1/2 x 9 Engine to gear input: 2.29:1 Pulls 32 FPM and 1800 lbs. single load; 16 FPM and 3500 lbs. double line Rapid-Reply starter for quick and easy starts Model G1800E
