My 87 has been getting around 18 mpgs. Now heres MY issue. It's a 23 gal tank right? I typicaly fill up around or just below 1/4 tank. This is in the neighbor hood of 180-200 miles. When I fill up, it gets around 12 or so gallons to fill.
12 gallons should be half the tank, not below 1/4.
I installed a new sending unit and intank pump last fall, and this did not change, and I did test the range on the sending unit before I installed it.
Does the sending unit when in the empty position only hang in the middle of, or slightly below, the 23 gal tank?
I had a 85 bBII with a 2.8 that the gauge didn't work, so I filled it up and then ran it till dry once to figure it's mileage, then zeroed the trip-ometer when I would fill it from then on. It seems like it got nearly 400 Miles to a tank, and I would fill it somewhere around 375 miles.
I think something is screwwy with our sending unit lengths.
