gas lines question?
yehaadon
I repaired a fuel line quick disconnect on the B2. The one that broke is the line that makes a 90 degree bend when it exits the tank. the other is slightly curved but mostly straight. my question is I turned the key on to let the fuel pump run to check for leaks and they were good. no I did not start it yet and was wondering if while running the fuel may return to the tank ? Im not sure which line was the broken one return or high pressure. dont want to start it and have gas flying ! lol.
smaller id line is return.
yes if you crank the key on and off a few more time it should finish priming and see some return fuel.
