- Jan 2, 2001
- Age
- 41
- Lancaster, Ohio
- Automatic
- Total Lift
- 5"
- Tire Size
- 35"
Question...
On our house we have a Wayne Daulton insulated garage door. It's a really expensive door and works great.
However, there was a gap around the edges that allowed light through when closed... so it obviously allowed air through also.
I got some rubber weatherstrip from work and installed it on the inside of the wood jam so the garage door pushes into it when it closes.
It sealed up the light/air issue, but now when I hit the automatic door opener, and it first pulls up on the door the whole top door panel...well...for lack of a better term shutters... Like it's having to pull up a little harder than it should. I don't want the door to break from jerking around more than it should.
Will this hurt anything? Or should I pull the stripping back off and try and find something smaller.
Surely there has to be something to seal the gaps.
The only thing there now is the finger strip that just touches the outside of the garage door and it attached to the outside trim.
If you need pics, let me know..lol
The white part with the nails is the flap trim that was on there.
The black strip is what I added.
