- Aug 10, 2014
- Age
- 33
- Madison, IN
- 4.0 V6
- Automatic
- Tire Size
- 215/70R15
I'm splitting this off another thread:
http://www.therangerstation.com/forums/showthread.php?t=166101
As it is in the urgent help section and since the thread doesn't look like it is getting moved out, I'm continiuing it here since it's no longer urgent.
(those that have read that thread can skip ahead a bit)
Anyway, to summarize, I bombed my transmission crossmember bushings, which some of you know are not replaceable (integrated with the crossmember). Coincidentally, I found a used crossmember sitting free at the Pull-A-Part while I was pulling an alternator for my wife's Taurus. Anyway, I destroyed the old crossmember during removal (rusted through-bolt) and discovered that the new one isn't usable as it was (presumably) tagged by a fork lift and bent/twisted beyond repair. This pissed me off enough that I wanted nothing to do with these bushings, and bought a raised crossmember on ebay, only to later find a 1994 stock bushingless crossmember at Pull-a-Part. One question (which led me to look for a such a stock crossmember) was whether or not a raised crossmember actually raised the transmission itself or only raised the ground clearance under the vehicle.
The new aftermarket crossmember came in today, and while I will be mailing it back for refund, I did take it out for some somewhat crude measurments compared to the stock bushingless unit.
First, this one may be a bit flimsy. It's only made out of 3/8" steel, not 1/2" like the better raised crossmembers. The 90 degree bends on the end are a bit sharp for comfort but otherwise the build quality is good (the powdercoat looks nice although time is the only way to test powdercoat).
In terms of lift, I measured around 1 3/16" of lift, from the top of the lower side of the frame rail (where such a crossmember would mount against) to the top of transmission mount slot.
I then performed the same measurement on the 1994 solid crossmember from the side that also mounts in the same spot on the frame rail. Ironically enough, it actually raises the transmission MORE. 1 1/2" to be exact, which is a full 5/16" higher. Not a whole lot, which leads me to conclude that the "raised" part, at least for the ebay listing, refers to ground clearance, not transmission height.
Tomorrow I'm drilling/grinding/chiseling/punching the rivets that hold the old crossmember brackets on and hopefully installing the crossmember. I also am replacing the transmission mount, as the rubber on mine was dry rotted and 75% gone. One side of the rubber was completely split, the other 50% split
. I bought the mount specified for the 1994 application, which should hopefully pair well with the solid crossmember without excessive vibration. I'll try to get some pictures as well.
