- Aug 11, 2007
- Age
- 38
i thought i had pics on trs somewere but i guess not.
started like this
first day wheeling legally at Tuttle Creek ORV
then the poo hit the fan and i was addicted so shortly there after
i got skyjacker 2inch coils, a set of bfg's on cragar 8s and added a leaf to the pack. i wheeled the piss out of it set up like this for almost 2 years. never broke a drivetrain component. i did however make an auto hub sing an awful tune. i added a lock-rock up front and Warn hubs somewere in that time.
but of coarse nuthing is good enough. so i set my mind on a n eb d-44 swap and then fell into a HP d-44 so i figured id bite.
the swap
wheels and tires where sold b4 i got started lol.
front end removed
mocking up axle. wich really wasnt needed its along story but with some reaserch on the web reading what others have found there is a hole in the fame on both sides that can be used to place the radius arm brackets i moved my axle forward inch& 1/2 though
this was actually the second radius arm mount i made. the first one would have failed. its made from 3/8 plate.
the first thing i realised was that the trans cross member needed modified. so a piece of c-channel was perfect. i would like to make a whole new cross member but this one is working well for now and im really busy. you can see also here the other side radius arm mount. they're square on the bottom so i can add a cross member later.
here is my trac bar mount. also a long story. also my second design. i should have done more research here. but im pretty sure this will work fine if didnt have high steer. the main points here are: drilled the steering box bolts and re-tapped for1/2 bolts instead of 7/16 and also bolted to the engi e cross member. anyone think this wont hold? if so i think im wheelin to hard lol. first pic is just to show off my use of the torch.
radius arm cross member i said i would add and did. should be able to see the gussets if you look. its 1x2 heavy wall square tubing. i jack the truck up by this lol.
the steering. let me just give an applause to Harsh Terrain. i got my knuckles spindles caliper brakets high steer arms and links from them. these guys know their shiznit. awesome to work with. ok now im done kissin ass. so its chavy knuckles machined for highsteer arms. chevy spindles caliper brackets and calipers. ford rotors and wheel bearings. i have chevy lockouts on it but i still have ford stub shafts its not right but it works. the ford shafts are slightly shorter. and silicone is not rust resistant.
i have had it out wheelin and will post pics later. got stuff to do.
started like this
the swap
front end removed
