Has any one ever tried to swap a mustang interior into a ranger? I haven't even begun taking a tap measure to things but just wondering if it's ever been done before
I would also suggest taking a good look at how the steering wheel and column connects to the dash. When I swapped a 96 dash into my 88 cab everything was close enough that it worked but I had to actually use the steering column and wheel from the 96 because of the way they attach to the dash. The 88 steering column simply would not connect in the same way since there was a joint near the firewall that offset the wheel from the column.
Always some hidden ways they need to move things around that best be addressed before rather than during a swap...![]()
