Linux_Geek
- Sep 24, 2007
I'm really wanting to upgrade my '86 Ranger S/C with a larger fuel tank. What is the latest model tank that will physically fit where the old 11 gallon one was? I don't care about whether the fuel pump that is located inside is the same as mine, just weather or not it will physically fit. I plan on removing the frame mounted one as it is and installing a HP intank pump in a larger tank that originally had the HP pump in it. The tanks are different if they originally had the frame mounted HP pump, and the in-tank low pressure pump.
D.
D.
