INFO Fuel Tank Dimensions
Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
TRS Banner 2012-2015
GMRS Radio License
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
As mentioned in the thread below:
I have been looking at the old BW1350/1354 Doubler pages to update them and searching to see if there's anything new, I can add to them.
An issue that people have run into is not having enough room between the transfer case and the fuel tank (gas tank) when you add an additional 6-7 inches with a Doubler in front of the transfer case. I began digging into that to clarify if the tank is always in the way, and if there is more room between the transfer case and fuel tank on a regular cab vs SuperCab Ranger. Does the tank sit farther back on a SuperCab (extended cab) than a regular cab, and are all the tanks the same length?
I had trouble finding any information listing actual dimensions of showing any size comparisons between Ford Ranger fuel tanks.
The owner's manual for 2000 Ford Ranger lists (3) fuel tank capacities:
Regular cab (Short wheelbase) 62.4L (16.5gallons)
Regular cab (Long wheelbase) 75.7L (20.0gallons)
SuperCab 73.8L (19.5gallons)
I found an eBay seller (77radrich_newoldstock4sale) that had a small variety of Ford Ranger fuel tanks listed and actually had the lengths listed for each one.
1999-2000 Ford Ranger fuel tank 58-inches long
1999-2000 Ford Ranger Fuel Tank 47-Inches Long
1999-2000 Ford Ranger Fuel Tank 58-Inches Long
1998 Ford Ranger Fuel Tank 47-inches Long 17-gallon
1998 Ford Ranger 17-Gallon Fuel Tank 47-Inches Long
2001 Ford Ranger Fuel Tank 57-inches long
2001 Ford Ranger SuperCab Fuel Tank 57-Inches Long
2002-2003 Ford Ranger 46-inch long fuel tank
2002-2003 Ford Ranger Fuel Tank 46-Inches Long
2002-2003 Ford Ranger fuel tank 58-inches long
2002-2003 Ford Ranger Fuel Tank 58-Inches Long
2004-2011 Ford Ranger fuel tank 17-gallon 47-inches long
2004-2011 Ford Ranger 17-Gallon Fuel Tank 47-Inches Long
2004-2011 Ford Ranger 19-Gallon Fuel Tank 59-Inches Long
I'm not going to discuss transfer case clearance here. I just wanted to make this a separate post for anyone that might be searching for information on gas tank (fuel tank) capacity and length.
If you have any information or photos to share, please do so. Especially if you have any photos to show side by side size comparisons.
I will probably move this to the 4WD Suspension Forum.
Hete are the capacities from my owners manual (3rd gen, 1993). I could try to get measurements next week when I'm off work again.
According to the 1996 Owners Manual, The 1996 Ford Ranger standard cab came with a standard 17-gallon fuel tank. The 113.9 wheelbase and 3.0L & 4.0L had an available 20-gallon tank option. The 1996 Ford Ranger SuperCab all came with a 20.5-gallon tank. So I have the 20.5-gallon tank.
I've noticed that some documentation lists 16.3, 16.5 and some seem to round up to 17-gallons.
I would be interested to know @Curious Hound how long your tank is, or if it's a 17-gallon or 20-gallon tank. You're 3.0L regular cab had the 20-gallon (19.6-gallon) as an option.
I'll need to get under there and measure. For some reason, I have always thought I had the 19.6gallon tank. I'm pretty sure I've put almost that much fuel in it a few times.
Event Coverage
TRS Merch
