1990RangerinSK
- Oct 5, 2016
- Saskatchewan, Canada
- 2.9 V6
- Automatic
Question - I know that my 1990 extended cab has a 15 gallon tank. Does anybody know it's dimensions? I'm mainly interested in height/depth. I'd also like to know if the filler neck is straight.
I theoretically ran out of gas at the beginning of February. So, I put just over 1 gallon in it to get me to the gas station, and then a few days later went and filled it. My "empty" tank took around 7.5 gallons to fill. I figured that the pump had cut out because it was filling too fast.
Today, I asked for $20.00 worth of gas. They put in $10.00 (I guess the pump cut out).
I'm getting really annoyed with never knowing how much gas I have in the tank. It was one thing when I figured that I could drive 30-40 miles on $20.00 worth of gas, and just watched how much I drove. I could reasonably expect that I was close to empty by the time I went to fill again. But to be "empty" and only take $29.00 to fill (should be around $60), and then to drive about 15 miles or so, go to put $20.00 in and end up with $10.00, this is ridiculous. You may remember another thread of mine at the beginning of February in which we were positing that my fuel pump was bad. I thought maybe I got off lucky, but now I'm not so sure.
What I want to do is make myself a dip stick, that I can dip into the tank and measure how much gas I have (unless somebody has a working pump assembly they want to give away, but then I still have to install it).
Thanks! Pictures of the path that the neck takes would also be useful.
