shr3dd3r 09
- Feb 24, 2011
- Huntsville, AL
- Total Lift
- 3 Inches
- Tire Size
- 33X11.5X16 (285/75R16)
My 2000 Ranger 5.0L is losing fuel pressure randomly while driving, and sometimes while idling. The truck will "stumble" or lose power a bit but usually catches itself and continues to run smooth. However, occasionally it will die altogether, but it will start right back up after cycling the power.
I replaced the fuel filter and that did not help at all. I picked up a pressure gauge and drove around with it attached to the schrader valve on the fuel rail. when the truck stumbles and loses power the fuel pressure drops down to 20 psi for a split second and then bounces right back up to where it should be. It usually hangs around 57psi except for when I have trouble.
It happens independent from engine load. I have floored it to recreate the problem but it seems like it randomly happens.
What should I check next? Seems like fuel pump, regulator, or wiring? Any tests I should do to determine what the problem is really?
I need help ASAP! This truck is my daily driver and I can't afford to get stranded. This problem needs to be solved quickly.
Thanks.
Thanks.
