Bstray83
Have a 94 2.3 and it's been giving me a fit. About two weeks ago once I turned the key on the fuel pump wouldn't come on until I cycled the key on and off for about ten minutes. Once it come on it primes properly and runs fine. So I changed ignition cylinder think that would fix the problem. Didn't fix it. So I continue having the problem daily. A few days later I think maybe it's the fuel pump itself, install a new pump. Turn the key on pump kicks on primes and drives perfectly for the rest of the day. Following morning back to square one yet this time pump kicks on and stays on, never primes or shuts off. So I begin reading forums and trouble shooting issues and haven't found a solution. I'M IN DESPERATE NEED OF HELP/DIRECTION!!!
What I have done:
Replaced FPR
Injectors (used out of another ranger I have that's totaled but ran perfect before being totaled)
Fuel filter
Relay
Inertia switch
Swapped ECM ( out of other ranger)
After trial and error I've found that my ground to my fuel pump relay isn't working so I jumped one in off the firewall ground so the pump will run when the keys on but it never primes. I'm completely stumped any direction or advice would be helpful.
What I have done:
Replaced FPR
Fuel filter
Relay
Inertia switch
