- Jul 20, 2009
- Age
- 38
- Ontario, Canada
- Automatic
Alright, so finally banged out most of this project in the last week or so at buds shop and was able to get the truck back home safe and sound.
However I got it towed because Im running into a small problem with the fuel system..
I had a Mr. Gasket 12s elec pump and was gunna use that with BadDad's guide on how to wire it and install it properly but decided on another route.
I got hold of a new Holley 12-841 regulator (4.5-9PSI) and used the existing fuel lines and in tank pump from the stock ranger system. I routed the fuel from tank to regulator in - to regulator out - to carb. Return from reg back to return line to tank and hooked up vent line from carb back to char canister and finally to tank.
However! The god damn thing is spitting out WAY too much fuel and flooding the carb and floats. The regulator isnt regulating anything. I know I have this hooked up right but what the hell is going on?
What do you guys think? Return line plugged? Bad regulator?(was brand new in box), or anything else? I bypassed the impact switch and the in tank pump runs fine but I cant keep this thing runnign unless I pinch the line until the gauge reads around 5psi..
Your thoughts please!
