Fuel Relay getting hot?
DomsRanger87
Have an 87 ranger with a v6- truck runs for a while then stalls- then when I try the ignition the relay does not come on after about 2 minutes the relay will come back and the truck starts fine-bad relay? relay getting hot? bad ground? anyone ever had this issue?
thanks-
replace the relay and if problem goes away relay was your problem if not start looking into fuel system (filter, pump etc..) check fuel pressure..
