Fuel Rail Hose
Kenobi77
Washington State, USA
2.9 V6
As luck would have it, the blue plastic hose/connector hooked up to the fuel rail decided to break right before I was going to put the engine in my truck. Have tried locating a replacement but unable to find any leads on what’ll work or even what to look for. Any advice?
Will be able to get pics later tonight if needed.
Mine did this.
I just cut the bad part off the end and worked the fitting back on. It was a bitch but some WD40 and a vice to hold the fitting i was able to work it back on.
^Viable solution. It's nylon fuel line. Any decent parts store should be able to get what ya need, but you'll have to bring them some pieces to match up.
