Fuel pump
atlantic
'08 Ranger. The rear tank mount has rusted off the frame so the tank has to come out. It has 133k on it and the pump has never been replaced. Should I put a new one in or do they last forever ?
Personally, I'd pressure check the pump and clean or replace the sock. Check the tank for sediment and clean it if necessary. At 133K I wouldn't expect you to have issues with it the pump, but it's also 18 years old. If you feel more comfortable swapping it out, you're still looking at a new pump's longevity vs. What may be OEM. I'm at 175K on my '08's pump and it's still going...
With aftermarket parts generally being a random mix of good and crap and name brands no longer being always good, it’s a crap shoot.
My F-150 is still running the OEM pumps but the rear tank pump flakes out sometimes.
Mom’s Explorer the OEM pump died at like 150k. I bought a Delphi and another name brand for it that I can’t remember at the moment and one was DOA and the other lasted about a month.
My green Ranger has a no-name pump because the OEM pump wasn’t pushing enough fuel at around 150k.
Choptop got an Airtex because when the tank started leaking (steel), the pump looked pretty crusty and I didn’t feel like fighting with it to swap it over to the new tank.
Best way to determine if the pump is ok is with a good filter in line (filters should be changed every 20-30k), check the fuel pressure at the rail. But that doesn’t really tell you much beyond being able to still put out proper pressure.
Thanks for the replies. It's sounds like a ain't broke don't fix situation.
