bobdog301
help! i have a 1995 2.3 with 421,000 mi and i noticed a pattern today
after i drive it and turn it off .....ready...if i try to start it 1-5 minutes after i shut it off, no problem, if i try to start it 20 min or longer no problem (wait for it) but if i try to start it in that 5-20 min range ,no go. bang on the tank nothing ,ko,ko,ko nothing , i have to wait till 20 min to start it, i have replaced the fuel pump at 325,000 mi (pep boys) and filter about 50k ago, yes i have not pulled any codes yet nor have i did a fuel pressure test yet
as i havent had time work / family obligations....ok i am lazy, now i will throw this into the mix, at 1/2 petel it bucks and misses bad,1 dead buck at a time,i spill my coffee, before i run around to check gas or spark or codes, did any of you guys experence anything like this, if so whatta you think, thanks Bob
