carcraft302
Well I finally got the Egine back in and hooked up and it runs GREEEEAT
. I now have oil pressure! The problem I now have is that the fuel pump won't shut off when I turn the key off and remove it from the Ignition. I need to disconect the battery, the green conector or the fuel pump realy in the fuse box to turn the pump off.
Is there a pressure shut off switch or any clues would be a help. I have gone through the wiring manuel etc and can't seem to locate a mistake. Anybody got any clues.
It seems like I go from one problem to another. Took me a while to figure out I needed a ciruit breaker instead of a fuse to power my fans but now they are up and running. I replaced the relay in the fuse box. As soon as I connect the battery the relay clicks on and the pump turns on and won't shut off!
