fuel pump relay???
1988Rangerxlt
is there a fuel pump relay i lost all power to both of my fuel pumps today any ideas? oh by the way its an 88 bronco 2
It should be over near the airbox. Mine is a green socket with a square black relay. Check there, I think theres only one other relay in that area.
Check to see if the inertia switch is tripped. If it's fine, test for voltage at the inertia switch with a test light. When you turn the key on 'Run', the fuel pumps will prime 2 times for 1-2 seconds each time. If it blinks, make sure power is going through it. There is also a fuel pump test on the diagnostic connector that can help isolate where the issue is.
Computer & computer relay also need to be functional for the fuel pump circuit to work. Easier to see how it works on a diagram, it's kind of hard to explain in words..
