cowtownkid
Hellow All,
Great Websit and the posts here have been extremely helpful. I recently purchased a 1993 4.0 with 73,000 actual miles. On Thursday I had some brake work done, replaced the gas fuel filler neck and fuel filter. After driving the truck home from the shop (about 30 miles) I let my son take the truck. He goes 4 miles to a park and stops. When ready to leave the truck will not start. I knew it was low on gas but not empty so I took him 1.5 gallons which we added and the truck immediately started and he drove it one mile to get gas. after putting 10 gallons in, the truck would not start again. When hitting the key, it fires weakly for a very brief split second then sounds like its not getting any fuel or even firing for that matter. After checking wire connections and everything else I could at the time, we had to leave it. I drove by the next morning on the way to work and bingo, the truck fired right up. I started it several times and drove it on home where it has started everytime. My mechanic said my fuel filter was the orginal and was badly clogged. Would this cause the pump to work extra hard and cause a premature failure and can the fuel pump work off & on intermitintently before completely failing? Any help would be greatly appreaciated. No check engine lights are on on the truck.
Thanks
cowtownkid
Thanks
cowtownkid
