E83
- Nov 13, 2016
- Automatic
Noticed a steady fuel leak from our 94 b4000 plow/yard truck a few weeks back. Finally got around to lifting the bed this weekend. Two days, four torx bits and an angle grinder later, I got the bed up.
Turns out that the metal "tube" that run out of the fuel pump assembly had rusted through on the feed line, causing fuel to stream out when running.
Since this is a pos yard truck that won't ever see a paved road again, I was hoping to pull the fuel pump, bypass the rusted out tube connector on top of the assembly and run a fuel line directly in to the housing and down to the pump, securing it with hose clamps and then using a fuel tank epoxy to seal around where the line runs into the housing. I am thinking this will work since based on photos of the pump assembly, there is already a rubber line running from the actual pump up to the metal tube at the top of the housing.
Of course, nothing is easy. Pulling the wiring harness resulted in it crumbling in my hand - will need to get a new one of those now... But even when I got the harness disconected, I couldnt for the life of me get the white plastic retaining ring on top of the assembly to unscrew. I tapped it, with a flathead and nothing.
So - even if I do install a new fuel pump assembly, it seems the old one is stuck in there anyway. Any suggestions on how to get this ring to budge? The amount of rust and corrosion around it suggests to me that a new assembly is needed anyway - but either way I have to get the old one removed.
Sent from my LG-H812 using Tapatalk
