Fuel Pump Issue?
Swiftkid
Put a fuel pressure guage on my B2 again after it was sputtering and dieing. It only had 35lbs of pressure at the rail and as i gave it gas at idle it dropped off within seconds down to below 20lbs...im assuming this is the reason for my B2 dieing at idle after only a minute or two of being started. The guy i bought it from claimed he put a new fuel pump in the tank and also a new pump in the rail. I changed the fuel filter and also the canister filter. What do you guys think i should do?
