jharms02
- May 6, 2008
- Age
- 41
- Lakeview Oregon
1962
- Automatic
My 1987 BII is stranded at the super market. It started then promptly died and would just turn over after that. Let it sit a for a few then it would start and promptly die. So I turned the key to the "On" position and listened, could hear the normal clicks under the hood, but not the whine of the fuel pump. so to confirm my belief that it's fuel related, I got a can of starting fluid and sprayed a dab in the intake. It would start and run until it used up the starting fluid. I hoped it was a fuse but without a book I do not know which fuse it was, or if the fuel pump has a fuse. So two questions Is there a fuse for the fuel pump, and if so, which one is it? And how else can you check if the pump is bad?
Thanks in advance.
John
Thanks in advance.
John
