reno
- Jan 18, 2008
OK, about a week ago I stopped at the circle K to get some muchies and when I returned to my truck, it would not start, like it was out of gas. I waited about 3 minutes and tried again and it started right up. Now this morning it does it again, except I am still in my driveway. I take my kids car to work.
I come home from work and try to start the truck again, it starts right up. I test the fuel pressure at the schrader and get about 31PSI running and around 40psi KOEO. Took the connections at the pump off, not to bad, but cleaned them with electronics cleaner, took a pick and scraped inside the terminals to try to make sure a good clean contact is made then put a dab of electric grease (like for lightbulbs) inside the terminals. Before replacing the connector, I took 200 grit sandpaper to the male connectors on the tank to clean them and then replaced the connector.
Then I replaced the relay and cleaned that connector as well. Now do I have good pressure? And if this continues, what else is left besides the obvious,a new pump? What is the best way (easiest) to find a break in the wire if it stays intermittent?
