Fuel pump bypass
Buddha62
i just got this truck and it wouldnt start. if i spray starting fluid into the throttle body it will run for a second.
the fuel pump is working.
when i pushed the shrader valve i had pressure but the fuel seems like it had qalot of water in it
i want to drain a half tank of fuel can i bypass the fuel pump and use it to drain the tank??????
not crazy about pulling the bed to take the tank out. so i would rather drain it
