tj37
- Apr 7, 2008
- Automatic
Hello everyone. I am having trouble with my 94 4.0 ohv ranger. I think it's the fuel pump but im not sure. Sometimes it will run ok but then it will start to cut out. I'll be going along and it will loose power. I can put my foot to the floor and go about 25. It will get a little gas but it wil buck like a bronco(horse not suv) until I can get it off of the road. It will usually start but sometimes it wont even do that. I switched out the fuel pump relay and thought it fixed it but I was wrong. Does anyone know what might be causing this? I just wanted to make sure that I am getting the right thing before I drop $100+ on a fuel pump.
Also, if it is the fuel pump, is there a aftermarket fuel pump that isnt quite as pricey as the OEM? I know where there is a cheap holley pump but I am used to old carb engines and I dont know how that would work with the computer.
Any help is appriciated.
Thanks,
Thanks,
