fuel problem ?? i dont get it
king.usmc91
snowcamp NC
okayy so heres my story and i really need help with all the issues i got goin on .. okay i got a 1989 ford bronco II v6 2.9 4x4 and it drove fine and everythings been good to me besides a tick in the moter but then a while back i was driving home and itd act like i was running out of gas and shut off then i could get it start back after a little patience and key turnning and it slowly did that till one day it stopped completly .. now ill turn the key and hear the fuel pump kick in and the moter will turn over but wont crank and stay running but if i shoot a little bit of ether in the moter itll run like a champ ha but i dont get it .. ive replaced the fuel pump/ fuel lines / coil pack fuel pressure regulator even cleaned the fuel rail fully and cleaned injecter heads ive done everything i get pressure iin the fuel rail even but it dont seem like its the right level of pressure idk all i know is i dont get it if anyone could pleace help im about to have to go drop all this money in the shop if i cant fix it on my own i gotta get my truck back on the road for work
http://www.therangerstation.com/tec...es/Diagrams_ElectronciEngControls2_9_1of3.JPG
Could be a bad fuel pump relay. Either jumper its contacts (B/Y to DG/Y) or run 12v to the inertia switch connector (PK/BK) and see if it runs.
I also had a FP that I had replaced fail a few months after I sold the truck to a guy. He found the 2" section of fuel hose wasn't fuel compatible (came with the pump) and had deteriorated.
Know how to use a meter?
Fuel
Hi, Had A Something Like This Happen To Me. 86 Bronco 2 2.9
I Had Replaced The Fuel Pump And It Was Running Fine.
Stopped At The Bank, And Then It Wouldn't Start!
Used A Large Paperclip To Bypass The inertia Switch (Emergeny Fuel Shut-off) And It Fired Right Up!
Still Runs Great! One Day I'll Replace The Switch.
Did You Replace Your Fuel Filter?
Good Luck.
