juice90
- Jul 12, 2014
About 3 weeks ago my 98 Mazda B4000 started acting up. Felt like it was running out of fuel. Just as quick as it stuttered, it took off again. It has done it only 2 more times since.
I just changed the old fuel filter, and opened the old one up and does look as if it was possibly plugging up but then again, I have seen worse.
Just did a pressure check and the pressure holds steady at 68 psi at both idle and reved up, only dropping about 1 1/2 psi when you initially open the throttle up and goes right back to 68 psi.
My truck has been sitting with the engine off for about 20 mins now and its still holding at 60 psi.
Should I be worried about anything? Looks to be ok, but I guess time will tell.
Oh no codes either. Anything else I should be checking?
98 B4000 4x4 4.0 liter 170,000 kms
